May have a problem.
mrmylanman
Hey guys,
I have had this motherboard (Biostar TPower X58) since January, and for the most part it has given me no issues, except for when I tried to do SLI on it.
I have two XFX GTX260s and one turned out to be defective. The computer would blue screen or refuse to boot (depending on the OS), until I removed the one card from the equation.
I returned that card and got another one, and for a couple months there was no problem. Now, it seems like it is doing the same thing again. I would like to think that my video card is not the problem (again) and I actually don't think that's the case. I tried taking one card out, taking the other card out, and swapping PCI-e slots, all combinations failed the same way (blue screen in Win XP). The interesting thing is that in VGA mode the computer will not crash. However, when I removed the nVidia drivers and tried to boot like normal, it blue screens still.
Can anyone make sense of any of this?
Since I tried all the combinations possible with the two cards (including just one installed on either slot), I am not so sure if it is the video cards that are flailing. Althouh the fact that it works fine in VGA mode seems to indicate otherwise...
Oh by the way I have had issues in Linux (Ubuntu and Fedora I have tried) and Windows XP.
Acer_Sheep
You should test the both cards on other computer, but I think this is mainboard problem.
mrmylanman
Yeah I'll have to find another computer to test them on. I guess I can go get my brother's desktop and stick it in there. His old Athlon 64 3000 would be a shame for the video card but I guess it would prove it works...
I suppose I'll be going through the RMA process for Biostar. I hope it's not a huge hassle. To be honest I want to just get another one instead. i7 is pricey though lol.
Another update - it is now blue screening in VGA mode too, so I guess I probably can rule out the video card. I'm trying Ubuntu again now that I took one card out to make as few failure points as possible, and I'll see how that goes.
mrmylanman
Well I'm not holding out much hope because earlier in Ubuntu (granted I had both cards in so maybe it'll be better) it wouldn't boot into X with the nVidia drivers installed. It always dumped me into the command line, so I tried to manually start X and it gave me the error
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Jun 20 12:55:41 2009
(==) Using config file: "/etc/X11/xorg.conf"
(EE) No devices detected.
Fatal server error:
no screens found
I'm thinking it could be the same problem, because that just means there's nothing that could run X on my system without problems. I guess Windows doesn't really do a check like that, instead just blue screens. I could be wrong though.
mrmylanman
Update - I got Linux working with one of the GTX260s.
Pretty poor timing for this to die, I am getting a monitor on Tuesday that is 1920x1080 and I was hoping to maybe put my SLI setup to more use.
Both video cards work. I tried them out individually. I don't know someone who has an SLI capable motherboard so I can't test out SLI on them outside of my own computer. Since it was working for so long I am assuming that the power supply is not at fault here.
