Syphon Filter
- Dec 19, 2003
Hi Guys,
I've got a Maximus VI Formula which I believe uses the RealTek ALC1150. I also have an Astro A40 headset with the wireless MixAmp (the MixAmp 5.8 I believe).
Now, my understanding is that the wireless MixAmp only supports Dolby Digital for surround sound. After doing some reading it seems that the onboard mobo sound does NOT output Dolby Digital, favouring DTS Connect instead for 5.1 audio.
Can anyone confirm whether this is the case? By using my Astro setup via optical am I only getting 2-channel audio which the MixAmp is then up-mixing?
If that is not the case then could someone enlighten me as to how I should configure my system to get the best out of the onboard audio and the Astro A40s (with or without using the MixAmp)?
If that IS the case then I guess I need to get a discrete sound-card?
Any help would be much appreciated.
