MATX case with external psu/no 5 1/4
Masejoer
Does anyone know of a case that is about the side of a matx case but can take low profile cards WITHOUT an internal power supply? I need to find a chassis to fit this motherboard into, using a single pci-e expansion board for now (Texas Instruments chipset Firewire), a DC-DC converter placed somewhere internally (above the ram slots is fine - I will mount this) and I will find some way to mount two 2.5" drives. I cannot find anything like this and I've come close with mini ITX but the motherboard and upgrade choices with that are horrible.
Ideas besides trying to make my own?
I currently have a Zotac ITX but it POSTs WAY too slow so I'm looking to get a matx instead (size isn't THAT much of a restriction). I'll likely just get something like the Foxconn G45M-S at 9.6" x 9.6" and mount it. The look of the case doesn't matter. I can cut cases or whatever but full metal fabrication is not in my ability list. Or you can do it for me, being right up the street (I'm over near Landmark Ford this second) :p
