MasterLiquid ML240L V2 RGB Liquid Cooling System $64.99
DrDoU
these are suppose to be very good coolers from what i have read. Gamestop near me might check into. 64.99 will not break the bank
kirbyrj
It really depends on the settings. I had a 240 mm AIO on my 5950 and it worked. I did not enable PBO though.
DrDoU
Bought one too go with my 3600 proc. Seems to be a bearing howl at idle that goes away as the cooler rpm ramps up. rgb isn’t that great either
fightingfi
I read that online review exactly what you said about teh fans and noise!
Reactions: DrDoU
