MikeTimbers
- Oct 10, 2001
Use a closed loop to water-cool the cards using generic VGA coolers instead of full-cover ones. That way you can re-use the blocks and they are much cheaper as well.
Then cool the closed loop's water with a heat exchanger pushing the heat into the mains water as suggested above.
BTW, this is incredibly bad for the environment and I kinda hope the whole bitcoin/litecoin etc thing crashes and burns.
Your mileage obviously varies.
