Astral Abyss
- Jun 15, 2004
Hi folks,
Last night I finished building my brothers computer and set about the task of reinstalling XP. Well, I forgot his CD didn't have SP1 on it (it was late and I probably should've just called it a night since this was a dumb oversight) and I tried to install the Nvidia chipset drivers without SP1. Well, after I realized I screwed the pooch by not having SP1 installed, I installed SP1 and reinstalled the nforce drivers.
What's happening is that I get massive data errors on the onboard gigabit NIC. The motherboard is an Epox 9NDA3+ with 3200+ 90nm A64. I've got an IP address assigned to the computer by DHCP on the DSL router. I can ping myself, the router, and can get to the internet but it's getting so many data errors that it just keeps hanging up while loading pages.
I'm at work right now, but I figure the best thing to do first is to try to uninstall the nforce drivers, run Driver Cleaner, and try reinstalling from a clean slate. If this doesn't work does anyone have some suggestions? Anything special I need to set on the nforce network config to correct this? I haven't used it before. I'm really hoping that the NIC isn't jacked up, but I haven't seen issues like this before so I'm kind of leaning towards that being the problem.
I tried a different cable on a differnt port on the router and tried the same port connected to the NIC on his laptop, which worked fine on the laptop. Tried rebooting the router and checked its settings. Everything looked fine, but no go.
Thanks for any help guys.
