Massdrop Vast: 35" VA 3440x1440 100Hz Freesync $549
Discussion in 'Displays' started by geok1ng, Oct 21, 2017.
  1. geok1ng
    geok1ng 2[H]4U
    2,132
    Oct 28, 2007
  2. DooLocsta
    DooLocsta [H]ard|Gawd
    1,528
    Jan 26, 2005
    This actually looks pretty good but I am wondering if they have to have overdrive on MAX to achieve that 2ms response time.
  3. Sancus
    Sancus Gawd
    905
    Jun 1, 2013
    Quoted response times are garbage anyway, especially for VA panels. The Asus Z35 had a 4ms one but the real one was like 9ms even with maximum OD at 200hz. I'd be very surprised if this one is much faster. And it'll still have the VA problem of >50ms black to grey (ie shadow) transitions that cause extreme smearing in dark scenes.
  4. Archaea
    Archaea [H]ardForum Junkie
    9,438
    Oct 19, 2004
    good price
    but make it in gsync.
    almalino likes this.
  5. MistaSparkul
    MistaSparkul [H]ard|Gawd
    1,039
    Jul 5, 2012
    Then it wouldnt have a good price anymore...
    257Tony, KazeoHin and Sky15 like this.
  6. Skott
    Skott 2[H]4U
    3,972
    Aug 12, 2006
    I saw it but I'm waiting for better due out this quarter. Acer and Asus are to have some nice ones.
  7. RPGWiZaRD
    RPGWiZaRD [H]ard|Gawd
    1,039
    Jan 24, 2009
    VA and gaming just doesn't mix IMO why highhertz gaming marketed monitors are a bit of an oddball to me. Sure contrast is nice but performance not so.
  8. Archaea
    9,438
    Oct 19, 2004
    Which ones are you watching for specifically?
    I’m interested in OLED or quantum dots, gsync 2, and HDR, though HDR is of lesser importance to me. I don’t need, or even want 1000 nits of brightness to blind me from my monitor in my dark basement theater room where I game. I do appreciate contest. But contrast in the manner of OLED vs contrast in the manner of a floodlight.
  9. Skott
    Skott 2[H]4U
    3,972
    Aug 12, 2006
    Looking for the 3440x1440 models Q4 2017. The Acer X35 I think is one of them. I get confused with all these model numbers anyway suppose to be really high Hz refresh. Also Q1 2018 they are releasing two new 4k models but I don't think I'll wait for them.
  10. Sancus
    Sancus Gawd
    905
    Jun 1, 2013
    X35 was delayed to match, so it's Q2 2018 now.
  11. Skott
    Skott 2[H]4U
    3,972
    Aug 12, 2006
    Crap! Figures it'd just be my luck. Well thanks for that info. I guess I'll have to wait a bit longer.
  12. DanNeely
    DanNeely 2[H]4U
    3,500
    Aug 26, 2005
    AUO has a reputation for flakier panels than their competition. Hopefully they're able to use the time lost due to whatever element is causing the delays on their next gen panels to also get them more consistent than previous generations have been. I also hope one of the other panel OEMs has similar high end panels in work but is just keeping quiet until they've got all the bugs worked out.
  13. darrpara
    darrpara Gawd
    678
    Apr 26, 2011
    Linus video on this monitor
  14. dholcombe
    dholcombe n00b
    40
    Mar 24, 2017
    At this point any new freesync monitor should really meet freesync 2 specs to be taken seriously.
    DooLocsta likes this.
  15. Bankie
    Bankie [H]ard|Gawd
    1,570
    Jul 27, 2004
    Are there currently even any decent Freesync2 monitors? The only ones I know of are the newer Samsungs and they're known for not having enough local dimming zones and being trash for HDR.
  16. dholcombe
    dholcombe n00b
    40
    Mar 24, 2017
    And this is even more trash than the Samsungs.
  17. AMv8(1day)
    AMv8(1day) [H]Lite
    125
    Jan 6, 2011
    Yeah because Freesync is so relevant with AMD putting out such garbage low performance/high wattage GPU's and selling all of 5 of them to reviewers before the rest of their stock goes to miners.
    Maybe one day, long after Vega is a bad memory, AMD will be able to compete in the high perf GPU market, and be able to push such high res monitors, but there is currently no purpose to putting Freesync on a monitor this high res with a 100Hz refresh rate other than because it's a free spec sheet tick box.
    Massdrop really should offer a $25-50 more expensive G-sync option. Sure G-sync costs more to implement and go through validation, but it shouldn't cost much more once they scale up production and they would still be hands down the highest value G-sync monitor on the market. The real problem isn't just cost though, it's the jackasses at Nvidia holding such a tight grip on their precious G-Sync market. Artificially limiting market options to keep prices high like they're the freaking diamond industry. It's anti-consumer and instead of everyone ignoring it in the hopes of not getting kicked out of the club, they should be getting called out for it.
  18. Thenewguy91
    Thenewguy91 n00b
    37
    Jun 14, 2017
  19. geok1ng
    geok1ng 2[H]4U
    2,132
    Oct 28, 2007
    You could take your opinions to the discussion about the blind test Vega+Freesync vs 1080Ti+Gsync. https://hardforum.com/threads/blind-test-rx-vega-freesync-vs-gtx-1080-ti-g-sync.1940556/
    The Vast 35" costs about HALF its Gsync competitors. That is $200 less than from the price gap described on the blind test, made at exactly the same resolution. If AMD was a value winner on that blind test, the Vast just increases its value.
  20. DWolvin
    DWolvin [H]ard|Gawd
    2,017
    Nov 13, 2002
    I know it's a necro- but did anyone here grab a vast? Is the 100hz native or overclock? Does it play nice with Nvidia cards?
