theshadow27
- Sep 7, 2004
DaRkF0g said:Can someone PLEASE explain to me why if I use 3 330ohm resistors they dont get hot, but of i use a single 1/2 watt 1K ohm resistor it gets burning hot? I dont understand why if you put 3 resistors in series they stay cool (wouldnt alot of current still be flowing through the first resistor?!)
every component in a series circuit gets the same amount of current, in this case 20ma. it is the voltage drop that makes the resistor hot, not the current flowing through it. by having 3 resistors, they each only have to drop 1/3 the voltage, thus staying 3 times cooler. welcome to electronics 101.
i would say no, as it only has to drop ~1 volt at 20ma. that is .02 watts, an order of magnitude less then .25 watt (1/4 watt resistor)DaRkF0g said:And if I DO use a 100ohm resistor in a chain of 7 would it get too hot??
