I can get a Dell 5224 for under $400. Its a 24port managed, all gigabit switch. The plan is to use it with 12 Dell 2324 switches(24x 10/100, 2x 1000, dumb switch) connected using the two gigabit ports. This would give the lan, 83Mbits per user, should be more than enough, there is no reason to ever be able to saturate that. (Current lan just employs two 2324s)
I plan on using the 5224 to vlan each 2324 and setting up routes so only the services I want can take place across the lan(Limits the spread of virii, port scanning, hacking, games get high priority, filesharing gets lowest priority(except to one of the official fileservers that host the patches and such), etc).
Is this the correct route, or should I be considering other alterntives?
