alphanumeric said:If It's XP Pro you may be able to lock it down with the group policy editor.
[Start] [Run] and type [gpedit.msc]
This is a very powerful tool so be careful what you do.
alphanumeric said:OK, if you go to start=>run=> and enter gpedit.msc you can run the group policy editer.
If you go to User Configuration, Administrative Templates, Control Panel, and finally Display, there is a "Prevent Changing Wallpaper" item in the right hand pain. If you double click it you can then go to the explain tab to see what it does. I beleive this will do what you want. If you already tried it and it didn't work then I don't know what to tell you.
