Make and Repair Your Own Cat5 Cables
Discussion in '[H]ard|OCP Front Page News' started by Kyle_Bennett, Feb 13, 2018.
  1. Kyle_Bennett
    Kyle_Bennett El Chingón Staff Member
    51,420
    May 18, 1997
    A long time ago I decided that I would build and repair my own Ethernet cables around the house and in the server rooms before the days of virtual servers came about. If you find yourself needing to repair or build your own cables, I just came across this thread in the HardForum that is short and to the point. As long as you can see fairly well, and have a strong grip, which I am sure most of you do, you can quickly be on your way to making your own and fixing those that you need to. Get you a crimper, some bulk cable, some RJ45 ends, your way Or just buy a kit. Certainly the tools have gotten a lot cheaper. I think I paid around $75 for mine 10 years ago. If you are going to be making a lot of cables, it is worth your while to grab a tester kit for Cat5 and 6. It can certainly save you time and keep you from running cable twice.
    Check out the Video.
  2. Betaboy1983
    Betaboy1983 [H]ard|Gawd
    1,262
    Dec 31, 2008
    Right on!
    Not that I have a lot of cables to fix/make and I couldn't justify a crimper. I would scrounge up some really short patch cables, cut them in half and solder/splice them onto whatever length I needed from my spool. Not very good to pull through tight areas, but it works!
  3. raiderj
    raiderj Limp Gawd
    341
    Jun 21, 2011
    That sounds WAY harder that just crimping a new end onto a cable.
    Brian_B likes this.
  4. Betaboy1983
    1,262
    Dec 31, 2008
    Maybe 10 minutes. Cheaper than a crimp tool though, it all depends on your situation/dire need.
  5. Parja
    Parja [H]ardForum Junkie
    11,482
    Oct 4, 2002
    You would have to be damn good at that for it to work for gigabit.
  6. Bearsahrk
    Bearsahrk n00bie
    4
    Apr 22, 2017
    This is by far a more superior RJ45 tool (or 11 because you can buy different inserts). Gives positive crimp feedback with a nice "Click". Front loading makes more sense than a side loading tool for cabling. Although expensive, it will eventually become one of those "Old Tools" that lives in your toolbox.
    [​IMG]
    Kyle_Bennett likes this.
  7. mullet
    mullet [H]ard|Gawd
    1,568
    Aug 19, 2004
    This is the tool and connectors I used to wire my whole house. Super fast and gets the twist in the cable right up to the connector.
  8. Burticus
    Burticus 2[H]4U
    3,551
    Nov 7, 2005
    I have a crappy criming tool I bought at a computer store about 20 years ago. It sucked then, it sucks now. But it works. However I have brought home so many boxes of "trash" ethernet cables that I don't think I have crimped one in many years.
    At work, crimps are forbidden. Cables must be bought intact and tested, and if there is the slightest problem they go in the "trash". Cat6 is fairly cheap nowadays compared to 20 years ago... ethernet TP used to be wicked expensive.
    Nowadays I deal with (and hate) more OM3 fiber than anything else.
  9. Tormond
    Tormond [H]ard|DCer of the Month - June 2007
    1,408
    May 4, 2003
    $17 on Amazon for a tool, ends, AND a tester. vs/ soldering that would be sketchy at best for data reliability
    BigJayDogg3 likes this.
  10. Betaboy1983
    1,262
    Dec 31, 2008
    Works great for me, but I've been soldering wires (and copper water pipes) for years. Like I said, I don't fix/make Cat5 everyday so I don't feel the need for a crimp tool. Just throwing another option out there for the fine folks of [H] if you're in a pinch! :muted:
  11. Poseur
    Poseur Limp Gawd
    342
    Oct 7, 2009
    Structured wiring is done with a punchdown tool, not a crimper. Buy patch cables unless you're super anal about the length being perfect.
  12. Sparky
    Sparky 2[H]4U
    3,186
    Mar 9, 2000
    Still have my crimp tool from years ago. I must have made 10k patch cords since 2001.
  13. OK, very much off topic, sorry. Here's the problem: my 77 year old mom pays Mediacom for 60Mbps, yet is lucky to get 20Mbps at her computer that is 25 feet away from the Modem/router. It dips every few seconds. Mediacom says that everything is just great, as the speed is fine. I don't mind getting a kit to make some cables. But my Mom is old and to run wired would entail running wires from the router, across the living room, to her computer. I'm not willing to provide a trip hazard, and her apartment manager won't let me route it around the ceiling.
    Ideas?
  14. Spaceninja
    Spaceninja [H]ard|Gawd
    1,595
    Sep 15, 2004
    Most of the cabling jobs we do at work are punch down terminations on both ends. I do occasionally have to make a random cable but it is about once a month at best. At home my cabling is a disaster. Not worried about it as I am moving soon and I'll get a proper rack for it all.
  15. lollerwaffle
    lollerwaffle Gawd
    637
    Feb 3, 2008
    Buy a short patch cord and try that first. Move the computer close to the router and use the short patch cord. That'll be a cheap, efficient test. If that resolves the problems, perhaps post a pic of the room so we get some idea. If I were you i'd probably affix a long CAT5 cable along the baseboard to the PC, it won't be a tripping hazard. You can buy white CAT5 with plugs on it, and you can buy staples and a staple gun that can affix CAT5, for about $20 max. It would look OK and not be a hazard. But before you do that, try a short wire to make sure that's the problem.
    Cerulean, Burticus and LightsOut41 like this.
  16. Oy, thanks. I'v run a 40 foot cable, and it works great. But from the router to the computer has a left gap and a right gap, for rooms. There is no obvious solution, to me.
  17. EODetroit
    EODetroit [H]ard|Gawd
    1,454
    Oct 20, 2004
    Been doing this for over 25 years. I originally made my own 10Base2 networks out of thinnet. Then bought some Cat5 and that spool has been with me ever since. I haven't wired my house with it, but my patch cable need has been fulfilled by that one spool ever since. Gigabit speeds are not a problem, even if it isn't Cat5e. Just don't try to make 100 meter cables, it works fine. If I ever get 10 Gig with copper (if that's even a thing), I bet it would work with short cables too.
  18. Thanks. I just can't hang cables, due to apartment rules. And I can't run cables on the floor, due to trip hazards.
    Burticus likes this.
  19. TitaniumLizzard
    TitaniumLizzard [H]Lite
    83
    Dec 30, 2009
    Someone knows their target audience!
  20. Jorona
    Jorona Font Snowflake
    3,242
    Nov 6, 2011
  21. leezard
    leezard [H]ardness Supreme
    4,377
    Aug 24, 2004
    This is what I use at the data center. My eyes are to bad to use a "traditional" crimper. I've made 1000s of cables with the EZ RJ45 and have never had a bad cable.
    mullet likes this.
  22. Burticus
    Burticus 2[H]4U
    3,551
    Nov 7, 2005
    Run along the baseboard with white duct tape pieces or cable tacks. If you have to go under carpet, do it at doorways.
    I've moved a million times and got really good at hiding ethernet / TV coax / and speaker wires along baseboards.
    That being said, wireless is pretty good now. A $50 wifi router will probably serve just as well... put it behind the cable modem. The cable modem's wifi usually suck nuts.
    Interesting. I've never use a "cheater" plug like that, where the wire goes through. But it seems awesome, I'm buying some of those. Cutting everything to the same-ish length, and keeping the pairs straight, and crimping properly through a normal plug end is pretty much a PITA.
  23. leezard
    4,377
    Aug 24, 2004
    You need the crimper also, it cuts the wire ends that stick thru the plug off flush.
  24. pclov3r
    pclov3r Limp Gawd
    420
    Feb 14, 2010
    To be honest there is very little reason to make your own cables unless you need a weird custom length.
    It's too easy to screw up and make a non complaint cable. You need to spend several thousand on a fluke tester to certify that the cable you made meets the specs. Doing it without that will work but you have no idea if it's compliant.
    It's even far more difficult to do it for cat6 and cat6a.
  25. Kyle_Bennett
    51,420
    May 18, 1997
    Talk like that will get you banned around here, your Softness.
    Methos, mullet, Todd Walter and 3 others like this.
  26. Tweak42
    Tweak42 Gawd
    593
    Dec 1, 2010
    If the cable modem and computer are in the same room, why not 5ghz wifi? (2.4ghz is typically way oversaturated in dense apartments)
  27. Dan_D
    Dan_D [H]ardOCP Motherboard Editor
    52,529
    Feb 9, 2002
    Wut? I've made hundreds of cables that all worked properly. Your average AT&T U-Verse installer can make them pretty quickly and easily. It isn't that difficult. Compliant? You don't even have to wire it to the A or B color code standards. It just has to be the same on both sides of the cable to work.
  28. nutzo
    nutzo [H]ardness Supreme
    7,221
    Feb 15, 2004
    Might be ok for 100mb or short lengths, but if you are running GB at 300 feet, I wouldn't trust the cables, especially if you have patch panels in between.
    As for building cables, I occasionally do this at home since the cables are usually short.
    However, at work, it's just not worth my time.
    It's cheaper for the company for me to buy pre-made cables and throw away any bad ones, rather than pay me to make new cables.
    I still have the tools, just in case of an emergency, but I can't remember the last time I built a cable at the office.
    Also, if you are running GB Ethernet close to the max length, and through a couple patch panels, you not only need cat 6 cabling, but proper cat 6 connectors that need a better crimping tool.
    10GB Ethernet is even worse when it comes to proper cabling and connectors.
  29. nutzo
    7,221
    Feb 15, 2004
    Actually you need to line up the pairs correctly. Each signal needs to be across a pair of wires.
    Which colored pair goes to which connections does mater as long as you match the pairs to the other side.
    Not correctly pairing the correct pins will lead to a cable that is flaky. Might work if it's short, but will have more problems the longer the cable gets.
    pclov3r likes this.
  30. pclov3r
    pclov3r Limp Gawd
    420
    Feb 14, 2010
    Yes, It will work often even if it's wrong. The reason I say "Complaint" is if your cable isn't you can start dropping frames due to corruption which will lead to packet loss. There is a lot of pre-made cables that even fail this badly.
    They have set standards for a reason.
    Things like crosstalk and EMI become an issue for example if you do something like untwist too much of the pairs. This is were you need the expensive fluke tester to certify the cable. Those cheap testers on eBay don't say much other than you wired the cable correctly.
    There is also a time factor. In a professional setting for common lengths nobody is going to crimp their own cables. They'll buy them in bulk form a place like Monoprice. Also it's much cheaper to toss a cable than to attempt to repair it.
    Perhaps I am looking at this too deeply or care too much about trying to do things correctly :)
  31. krotch
    krotch [H]ardness Supreme
    4,518
    Aug 12, 2004
    Sounds like my work. Everything is just pre-made cables. It's annoying cause the cables are too long or too short. Usually way too long to be used at the patch panel. 1 1/2'-2' length needed, no cables under 5' length.
    Luckily, our network shop has spools of cable. Just no connectors or crimpers. I have my own though.
  32. T_A
    T_A Limp Gawd
    381
    Aug 4, 2005
    I wouldn't use this cable in my house , i run cables in the walls (concrete and blocks) and EMI can be an issue without shielding.
  33. kju1
    kju1 2[H]4U
    3,018
    Mar 27, 2002
    Heresy...
  34. lilbabycat
    lilbabycat 2[H]4U
    3,823
    Jun 21, 2011
    Route it around the ceiling anyways using those non-damaging sticky hooks/loops. Easier to ask forgiveness than permission.
  35. KarsusTG
    KarsusTG 2[H]4U
    2,846
    Aug 27, 2010
    I have done this for as long as I can remember. The Cisco standard 1236 config (orange white, orange, green white, blue, blue white, green, brown white, brown) has been stuck in my head since I was a teen.
    Burticus and Kyle_Bennett like this.
  36. zkostik
    zkostik Gawd
    822
    Sep 17, 2009
    I'm good at soldering and I fix about any damn thing I possibly can but even then, I highly doubt I'd do something like splicing two ethernet cables together unless it's in the wall or something and gets damamged so you have to fix or pull new one.
    Either way, I'm really glad to see this post and that folks do this to reuse their cables. It helps save money (if you get components to crimping in bulk) and above everything keeps them out of a landfill! I wired pretty much most of my house and will likely end up making short cables of exact needed length for my server rack with left over supplies.
  37. Dead Parrot
    Dead Parrot 2[H]4U
    2,146
    Mar 4, 2013
    Usually cheaper and easier to buy premade. But there are times when you want/need a cable NOW and it sure is nice to be able to make just what you need. Especially when it is some odd length or the hole for the cable needs to be as small as possible. I do need to pickup a tester as using the active connection light on a switch is a bit primitive.
  38. krotch
    4,518
    Aug 12, 2004
    I spliced together plenty of ethernet cables when deployed. We had cable, but no connectors for 2 months. We literally had only like 9 connectors and they were reserved for anything important. Anything else consisted of us cutting cables, twisting the wires together, and using duct tape. We eventually got more connectors.
    Aside from lack of connectors, some of the runs were simply junk. Instead of digging a small trench for the wires, they simply laid it on top of the rocks. Doesn't take long for MRAPs to screw your cable up. I ended up digging a trench by hand, laying sand bags down, laying cable, then laying sand bags on top. A few other times made a conduit using old mortar ammo cans. Shoot guns at one end to make holes large enough to run multiple cables. Had no drill bits.
    Working with the Army...way different than working with the Airforce.
Tags:
