ben chi(f4)
- Mar 4, 2008
Someone installed the OS on the D drive and I need to change this to the C drive. Can this be done without corrupting everything?
You might just want to do a fresh installation.
thanks is what I thought... fml.
Warning Do not use the procedure that is described in this article to change a drive on a computer where the drive letter has not changed. If you do so, you may not be able to start your operating system. Follow the procedure that is described in this article only to recover from a drive letter change, not to change an existing computer drive to something else.
From the Microsoft Article:
This basically says if during installation, the drive where the OS was installed on, was made say D, then you cannot ever change it to C, you must re-install Windows.
