Sandy Bridge, I think, is going to be the start of a lot of good changes and improvements in mobile computing, especially given the battery discharge figures measured at Anandtech. That was with an early laptop with a quad core running Windows. First off, I'm not convinced that Windows itself is the culprit when comparatively lower battery life versus OS X is found in identical Apple hardware. I think most of the delta in consumption is due more to drivers and the GPUs under Windows not being switched to save energy. So I'm no fanboy.
That said, Apple's focus on consistently delivering more and more battery life over time is probably going to leave them with a lot more headroom than before to incorporate features that normally are more energy hungry, all while still keeping the discharge figures above and beyond prior systems.
What would you change, remove, or include in the upcoming lineup?
I'd like seeing:
- IPS LED-backlit displays at higher resolutions
- improved Windows support
- an integrated 3G or 4G modem
- optional quad core CPUs
I'd like seeing:
