Anyone have any experience running FSX on your mac?
How has it performed and what are you using. Mac Pro? Macbook Pro?
Bootcamp? VM-Ware? Or did you just install windows on its own partition?
Thanks!!
While I wish you the best of luck, I can only honestly chuckle under my breath at the thought of this. The MacBook just doesn't have the horsepower to really drive FSX.
BTW, use BootCamp since it'll let Windows run directly on the hardware. VMWare has no 3D acceleration to speak of, so that's a complete non-starter there.
Boot Camp would be a no-brainer. The fastest way to run anything is completely natively.
