M3A78 EMH HDMI
NTJedi
Motherboard = M3A78 EMH HDMI
I'm setting up a triple boot environment using Windows2000, WindowsXP-64 and Vista-64 yet there's no chipset drivers available for the Windows2000. I have successfully installed all other components with great success. I know the Windows2000 OS is not supported yet is there a way to force an installation of the WindowsXP-32 bit drivers?
I'm not sure if it will work, but I'd like to give it my best shot.
Has anyone else tried using Windows2000 on the M3A78 EMH HDMI motherboard ?
NTJedi
My Windows2000 installation still needs the chipset drivers from the motherboard... anyone have some suggestions?
thebeephaha
That board is using a very new chipset. I highly doubt it will work. You could just run win2k within a virtual machine in the other OS tho... Might be easier.
joyntkid
Sorry to hijack your thread, but have you gotten the HDMI out to work in XP?
I have the same mobo, but I just cant get HDMI to work.
I changed the jumpers, set the VBIOS to hdmi, and it still won't work.
