M3A778-T Onboard Video Question
kbaer89
I have a MoBo with the 790GX chipset. It has onboard HDMI and DVI output. Will the onboard video work when I have a GPU in the PCI-E slot?
I can't get it to work although I haven't tried removing my video card.
nope.. will not work when the other card is in.. board doesnt support hybrid crossfire if i remember correctly.. and even then hybrid crossfire only works with the HD3450 i believe..
I disagree, and I believe he may be talking about SURROUND setting for graphics adapters in the BIOS to enable multiple monitor support. Sort of like the "new" Eyefinity feature.
Multimonitor != Eyefinity.
Most games do not allow for multi-monitor.
Eyefinity makes them work on multimonitor.
NOTHING else at the moment does that.
Hybrid Crossfire is a xfire setup between the onboard GPU, and a dedicated card, via the PCIe link.
This mobo is this:
http://usa.asus.com/product.aspx?P_ID=PaJTmB4aZ9WAYnM6
which has hybrid xfire, and sideport memory, but no SURROUNDVIEW (690G and 780G only), which simply runs both GPUs seperately, instead of xfiring them.
