How much of a pain in the rear is it to remove the SIM card?
Does it feel too large?
Which color did you get?
How's the battery life?
Any pics of the thing?![]()
I swear I can remember reading somewhere that the SIM slot was on the top or some such? I don't think the unit comes apart per se, there has to be a slot somewhere on the exterior since it's a unibody design.1. I still haven't figured it out lol...
Does it stream bt audio while wifi is on? All my samsung windows phones can't do this
the top has 2 flaps, slide one open for the usb charging thing, the other one is a 'press on the opposite end' to open it, and your microsim should go in there
I messed around with a couple 900s at SXSW. The camera is no better than the 800. The phone is pretty big and heavy too.
Will probably wait till it actually shows up at the ATT stores before making a purchasing decision. Bit of a bummer since in my past experience with ATT the phones would arrive at the store like a week after they started selling them online but size matters, except with gadgets it's the other way around, you don't want to carry a kindle in your pocket.
Little heavier than HTC Titan.
HTC Titan 2 on the other hand feels like a brick compared to Lumia.
Feels solid to me, camera is better than 800. The FFC is amazing.
And one more question that is not related to the phone... Is there an equivalent to Google Sky for Windows Phone?
Is it scratch resistant and easy to clean? You think it'll do fine without a protective case?
I DISLIKE case, but had to get one for my T-Mobile HTC G2 because the edges started to turn yellowish after a couple of weeks and couldn't clean it off.
Thanks!
Does it still have the "ACTA" bug? - some series of letters/numbers/symbols showing up in text/facebook coment, mail or such will freeze the phone, and it needs to be sent to tech support for reset. Reset will also result in erasing all user data - contacts, mail, documents, files. This bug appears in Lumia 800 and is not a phone, but rather Windows feature... was also named ACTA-text bug, because it could be used, after introduction of ACTA/SOPA to deactivate phones which had some content that was breaking those agreements.
Haha can you provide a link to that? I've never seen anything on the other tech sites about a text bug requiring you to send your phone in to be officially reset (contacts/mail are sycn'd with Hotmail/Live accounts by default, docs/files can be set to sync with SkyDrive by default as well... so it's not the end of the world if you brick your phone).
How's Windows Phone compared to Android?
FWIW, went to the ATT store today, manager told me that the phones will be in store on April 8th. The demo units are only available to employees and will not be on the floor prior to official release.
Want. Know how much it will be without contract?
Can you give us an update on battery life while on 4g?
