pendragon1
Extremely [H]
- Oct 7, 2000
haven't seen this here or remember anyone else doing it... I could be wrong but here it is anyways. ~20c drop on cpu is pretty damn good.
I've been needing to replace the TIM on my old laptop for a couple years now. Unfortunately I downloaded the service manual and getting to the cooler requires the removal of over 100 screws, the keyboard, screen, bluetooth and USB boards, the lot.
I said fuck it as I have nearly no experience working on a laptop.
move the hippy lamp and you should shave off an hour
you haven't worked on hundreds of different laptops have you? some are so cheap they are disposable but that doesn't mean they cant be repaired. ive personally done $100-3000+ laptops, all repairable. now if you said most are not designed to be user serviceable I could agree....
