yoyosuper8
- Mar 12, 2015
Hi, I recently acquired an LSI MegaRAID 9260-8i with a battery backup and 512MB of internal RAM. This card provides hardware raid 0, 1, 5, 6 and raids 10, 50, 60 span.
I am currently seeing 50MB/s write speeds and 40MB/s read speeds. I was expecting write speeds of 100MB/s to 200MB/s and read speeds in the near 100MB/s. I don't know what else to do or how I should change my setup in order to increase the write/read speeds.
I created two spans (each span has two 1TB drives assigned to it) in order to create RAID 10 array.
Here is how I have setup the raid 10 array in the LSI WebBIOS:
PROPERTIES
RAID Level: 10
Status: Optimal
Strip Size: 1024KB
Capacity: 1.818TB (Four 1TB drives 7200RPMs Western Digital)
SSD Caching: Disabled
POLICIES
Access: RW
Read: Normal
Disk Cache: NoChange
I/O: Direct
Disable BGI: No
Default Write: Write Back with BBU
I have VMware ESXI 5.5u2 on a separate hard drive. In the ESXI I created a new datastore for the array. Then, I created a virtual machine onto another datastore and added a new Hard Disk and pointed to the new datastore for the raid 10 array. In the virtual machine I installed Windows 7 in which I created a new logical volume GPT, then I network shared the new logical volume and from another computer in the network I'm uploading and downloading large ISO files of 3GB or 4GB.
That's my current setup. Does anyone have any input or ideas on what I can do to increase my read/write speeds? Any help is appreciated. Thank you.
PROPERTIES
RAID Level: 10
Status: Optimal
Strip Size: 1024KB
POLICIES
Access: RW
Read: Normal
I/O: Direct
Disable BGI: No
