LSI 9305 not detecting HGST SAS drives
rigurat
My LSI 9305 24i is not detecting HGST 4tb 4kn SAS drives. It sees other SAS/SATA drives just fine.
I've done the obligatory pre search, and I found this https://forums.freenas.org/index.php?threads/lsi-hba-sas9305-24i-no-disk-spinup-at-boot.53534/ and https://forums.freebsd.org/threads/60688/ Very close to my problem except my drives aren't being detected at the controller card level.
Controller information
Controller type : SAS3224
BIOS version : 8.35.00.00
Firmware version : 15.00.00.00
Channel description : 1 Serial Attached SCSI
Initiator ID : 255
Maximum physical devices : 1023
Concurrent commands supported : 5888
Slot : 1
Segment : 0
Bus : 5
Device : 0
Function : 0
RAID Support : No
The card has the latest BIOS and firmware. The motherboard is a Supermicro MBD-X10-SRL-F with latest BIOS.
The card isn't detecting the drives at all. They don't even spin up. Entering the card's BIOS doesn't show the drives even if they are connected, and I have 8 of these. They are connected though Norco 4116 case backplane.
The intended setup is to become a FreeNAS server.
I suspect it may be incompatibility issues, but this controller is recent enough to handle 4kn drives.
