Lower end upgrade of an old 8800 gt 256mb
rbarr110
So my kids PC has an ageing 8800 GT 256 MB card that has started given some crashing errors and also has an obnoxiously loud fan.
I want to slightly "upgrade" the card, but don't want to go nuts, the new card would be going in an aging Athlon X2 5800+ machine(or something along those lines).
My main PC has a good video card for the newer games that may need more horsepower, but so far the 8800 had been handling everything they play (older games, minecraft, starcraft...)
Any sub $100 suggestions?
sub 100? the cheaper radeons arent too bad and should fit the bill for you.
You could get a GTX550ti, which I think is around 150 or less now which would be quite powerful and play todays games pretty well.
I've seen GTX 460's used on the various hardware forums for under $100. Would be a good option.
I don't do used cards, so I'll try to make some new recommendations. Just keep in mind that the sub-$100 market still doesn't look so hot compared to the venerable 8800GT/9600GT cards. Both still have a lot of juice in them (especially the 512MB+ versions).
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127577
^grossly overclocked 550Ti for $89.99 after MIR
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500193
^Almost as highly overclocked Zotac version, but custom ports (2xDVI, full HDMI, DP), $99.99 after MIR
The 550Ti is a surprisingly good modern performer, and I was shocked to see those MIR deals. As for the Radeon cards, the 7750/7770 are more expensive and don't perform as well. The 6850 is the next step up, but cheapest I saw was $124.99 after MIR.
? .7770 clearly outperforms the 550TI. You are correct that the 550TI will destroy a 7750 and at sub $100 prices after rebates it is a great value. At $130 normal pricing the 7770 is a much better choice. If you are just looking at after rebate prices this $100 MSI N460GTX-M2D1GD5/OC2 is a much better card than the 550.
A 550 Ti for $100 or a 7770 for $115 are good choices. You might have to shop around or wait for a good deal if going for 7770. If you have just $100 to spend you have to look at last gen or used cards.
You guys are going way overkill on the cards. You could find another used 8800gt for around $30-40. Or a gtx 260, gtx 280, gtx 275, or gtx 285 around $50-60. Also ati 5770's for $70
You're right. I had to refresh my memory. Not sure what I was thinking. The 7770 does beat out the 550Ti in most games. However, the OP wanted under $100, so that's out of his price range. Also, I see the 7770 and 6850 priced pretty much on par (cheapest after MIR is $119.99 for 7770, $124.99 for 6850). The 6850 is slightly faster, but the 7770 requires much less power.
While the 7770 and 6850 are excellent buys, I stand by my 550Ti recommendation due to the above-average performance and the under-$100 price. If the OP can stand to go up to $125, however, one of the Radeons would be a better choice.
With that cpu there is no point of getting a gpu that fast. He should get a 5770 or something like that.
I'd also suggest a GTX 460 or a HD 5770, used in either case. Then when you're ready, upgrade the CPU to a better speed quad-core.
as hotcrandel said. 5770 and 460 are your best bets. get whichever you find cheaper. however 5770 will be the cooler one..
Thanks for the opinions and links!
I am not confined to $100, but I don't want to put much into the kids PC, because they arent really taxing it with what they do, I just think that the current 8800 GT video card is on it's last legs with the errors and crashes that are happening.
If I end up being wrong that it isnt the video card, I wont be out a lot of money.
Thanks again!
