My system with all of the above is loud!!! I'm using the stock HSF which, according to AsusProbe, is generall about 4000 RPMs. The monitor on the AsusProbe is showing the Chassis fans operating at about 2000 RPM. The 9800XT fans are going at about 4-5000 RPMs too (and the facking chip is at like 65 C? Is that safe?)
I cut up some anti-static foam and taped it inside the case (about 5 strips places around the case), hoping that would absorb some noise, but it didn't much. Am I just stuck with a loud case with all of these fans, or is there something I can do?
Maybe a new HSF?
Maybe a new HSF?
