Lotes Intel CPU Socket Holder LGA1366 LGA 1366 I7
Discussion in 'Intel MoBos' started by waseem, Apr 8, 2012.
  1. waseem
    waseem Limp Gawd
    346
    Oct 14, 2008
  2. waseem
    waseem Limp Gawd
    346
    Oct 14, 2008
    "....Say there was a bent pin...." on a Socket...
  3. DTN107
    DTN107 2[H]4U
    4,059
    Jun 30, 2008
    It is no where near plug and play when replacing the socket.
  4. waseem
    waseem Limp Gawd
    346
    Oct 14, 2008
    so can i replace it or ?
  5. Crosshairs
    Crosshairs Administrator Staff Member
    23,504
    Feb 3, 2004
    is it replaceable, yes, can you replace it.? no...
    unless you have the right equipment, which if your asking this question, you most certainly do not have
  6. waseem
    waseem Limp Gawd
    346
    Oct 14, 2008
    wich equipment dos i need ?
  7. waseem
    waseem Limp Gawd
    346
    Oct 14, 2008
    i don't know wich equipmen i need so if there a youtube or link that help ... or just write it ... to know.thanx
  8. Crosshairs
    23,504
    Feb 3, 2004
    you need one of These :D
    They make smaller ones, but you get the idea..
  9. waseem
    waseem Limp Gawd
    346
    Oct 14, 2008
    are you sure that there is no way to reaplace it with out this huge mach?????
  10. Crosshairs
    23,504
    Feb 3, 2004
    They make smaller ones..I have seen them for as low as $6,000.00.....not really practical for your scenario
    you could try and send it to Asus for repair......they may be able to do it for a small fee..
    the bottom line is replacing the socket is not something your average person can do.
  11. FourPlay
    FourPlay Limp Gawd
    143
    Jun 5, 2008
    26k is a small price to pay to save this legendary 1366 motherboard.
  12. waseem
    waseem Limp Gawd
    346
    Oct 14, 2008
    You can pay it if you have a big pocket
  13. Zinn
    Zinn 2[H]4U
    2,125
    Jan 31, 2010
    I bent a couple of pins on a motherboard once. Like everyone said, home repair isn't really an option. Ended up selling AS IS / DAMAGED on eBay and actually got a decent price for it. That may actually be your best bet...
  14. Acer_Sheep
    Acer_Sheep [H]ard|Gawd
    1,205
    May 18, 2007
    You wont replace the socket just like that as it is soldered into the board and as you already were informed above, you need a soldering station in order to do that. There are 1366 contacts underneath the socket each soldered separately, in home environment you don't have any option to replace the socket, unless you want to destroy your board.
  15. mothman
    mothman 2[H]4U
    3,858
    May 28, 2009
    Asus should be able to replace it for you at your exspense. The socket itself is soldered to the board at so many different tiny points that you would have no way to DIY it.
  16. waseem
    waseem Limp Gawd
    346
    Oct 14, 2008
    AHA I understand that the socket soldered to the board ... so 100000thanx .
  17. Llama[Style]
    Llama[Style] Limp Gawd
    482
    Mar 7, 2011
    As others have mentioned...just RMA it...ASUS will replace it for like $25. Shit happened on my Maximus III Gene. Doesn't take them long either.
