pendragon1
Extremely [H]
- Oct 7, 2000
oh ok. she can try it and see i guess. i doubt it will make that much of a difference since its just the centre and is mid/highs anyway.Seems that the center channel's going to sit inside a box and also block most of the front opening. This will create another resonant chamber, and affect bass loading. Especially if the speaker has ports other than on the front.
How many center channels are designed with this placement in mind? Near a wall? Sure. Enclosed by walls on 5 sides? Different story.
It may not make much difference, because the affected wavelengths are so long. OTOH, pulling the speaker out to plug the ports later might be a bit of a PITA, so I'd prefer to consider possible effects ahead of time.
