Looking to go to 10gb at home; should I do multi-gig switch?
RavinDJ
I'm looking to get 10gb running at home. I'm confused whether I should get one of those multi-gig switches that does 1/2.5/5/10 or just a full-blown 10gb switch.
Which way do you guys go and what do you recommend?
Probably looking 8-12 port; probably through Amazon (or is there a better retailer/e-tailer?).
Backbone is Cat6 cabling throughout the house.
Me, personally, I have the QNAP 12-port since it has SFP+ and RJ45.
https://www.amazon.com/QNAP-QSW-120...AP&qid=1570649758&rnid=2941120011&s=pc&sr=1-3
I'm using Aquantia AC107 NICs in my comps.
https://www.amazon.com/Aquantia-NIC-5-speed-Ethernet-Network/dp/B07C5VLVFF/ref=sr_1_1?crid=255WU1D82WJ4V&keywords=aquantia+aqc107&qid=1570649847&s=electronics&sprefix=aquantia,electronics,287&sr=1-1
I'm happy with it so far.
How long are your cat6 runs?
10G is not rated to work over cat6 at 100 meters. I think it will only work at 40 meters, tops. If you need to go longer, you need to upgrade to CAT6a.
It's a 2-story townhouse... at most, maybe 100-120 feet, which is at most 30 meters. But good call!! Definitely will keep in mind for future runs.
You might as well do the 10g switch instead of multi-gig, better support, more options
Netgear and FS have 'cheap' 10GB switches
You could pull armored fiber
Are you going to need 10GB everywhere or just between a few machines?
I was going to snag one of those 16-port managed netgear 10GbE switches but am vacillating on whether to stay cat 6a or just go fiber in the walls.
Fiber is nice if every device has SFP+ ports which isn’t the case in the consumer world. I would stick to 1/10G-baseT for the home devices. I would save the fiber for switch uplinks, server stuff ( Twinax for sub-7m Connections is nice too), although you can run fiber to a desktop if you have a NIC with SFP+ plus ports in it, but I wouldn’t bother if you can get a mobo with a 10G port already. If you want to do it the right way, have your wall runs terminate at a patch panel, which you can patch your switch to.
