Looking for something to cover desk surface and be usable as mousepad but can't find the right term
Discussion in 'Gaming & Office Furniture' started by viivo, Jul 2, 2018.
  1. viivo
    viivo Gawd
    948
    Sep 7, 2005
    The desk surface is 72"Wx28"D. I'm looking for something close to veneer, but thicker and more durable like truck bed liner and also slick/smooth enough to use a mouse on it. Anything like the texture of a Ratpad that comes in large enough sheets that I can cut to fit the desk top?
  2. DrLobotomy
    DrLobotomy [H]ardness Supreme
    5,359
    May 19, 2016
  3. viivo
    viivo Gawd
    948
    Sep 7, 2005
    Does melamine come in thicker sheets? All I've seen is paper thin covering on fiberboard shelving and such.
  4. DrLobotomy
    5,359
    May 19, 2016
    Formica is the name brand of cabinet top covering that uses Melamine. Definitely not paper thin. You use a type of resin to apply it normally.
    viivo likes this.
  5. dwd999
    dwd999 Limp Gawd
    158
    Oct 8, 2009
    viivo likes this.
  6. ItWasMe
    ItWasMe n00b
    38
    Jun 21, 2018
    Alibaba has large sheets of ESD rubberized material. It is what my Lab people order to replace their workstation tops.
    Cant link to it because I'm at work, but if you search for 'ESD table mat', I'm sure you'll find something.
    KarsusTG and viivo like this.
  7. westrock2000
    westrock2000 [H]ardForum Junkie
    8,899
    Jun 3, 2005
    28" is under 1 yard, so you could also buy simulated leather from any fabric store.
  8. Lifelite
    Lifelite 2[H]4U
    2,753
    Aug 26, 2015
    I use a MTG play mat, might not be as big as what you are looking for but it def works well
  9. TeeJayHoward
    TeeJayHoward Limpness Supreme
    9,207
    Feb 8, 2005
  10. Ultima99
    Ultima99 [H]ardness Supreme
    4,931
    Jul 31, 2004
    But then he wouldn't be able to use metal utensils...
    Brian_B likes this.
  11. zeeDj
    zeeDj n00b
    59
    Dec 23, 2015
    FNtastic likes this.
  12. ZeqOBpf6
    ZeqOBpf6 Gawd
    581
    Aug 24, 2014
    i lost my shit at the submarine
    how do i replace my skin with this
  13. FNtastic
    FNtastic [H]ard|Gawd
    1,269
    Jul 6, 2013
