looking for recommendation’s on esata raid enclosure
Discussion in 'SSDs & Data Storage' started by Putz, Jan 22, 2014.
  1. Putz
    Putz I have a custom title
    5,281
    Jul 8, 2002
    looking for something like this:
    http://www.sansdigital.com/mobileraid/mr4ut.html
    but reviews for san digital suck, i need something that is external, will give me 4tb of redundant storage after raid (so either 2x4tb drives in raid 1, or 3/4 x 3tb drives in raid 5 (prefer 6 but most dont give this option)
    it needs to have USB 3 and esata and do the raid internally
    suggestions?
    long story short i know its not a great setup but its only for an offsite repository for appassure backups, they were using USB drives and every time they tank we need to reseed a few tb of data... stupid setup, the server is a power edge 2900, internal bays are full, and is has a couple of perc 5 cards for an external array already, so ill be adding an esata card for this, usb onboard is 2.0
  2. clearwaterms
    clearwaterms n00b
    15
    Jan 21, 2014
    What about something like enclosures from pc-pitstop.com
    They have some rack mount 4 bay as well as stand alone 4 bay enclosures. Most of the enclosures that they make have ZERO intelligence, just a powersupply and a SFF connector.
    http://www.pc-pitstop.com/
    In the past, I built a configuration with 8*3TB drives powered by an HP P412 card /w BBC (HP Proliant server) and it flew. The best part was that because the drives were just drives, HP still supported the card when I needed tech support.
  3. Putz
    5,281
    Jul 8, 2002
  4. Aesma
    Aesma [H]ard|Gawd
    1,844
    Mar 24, 2010
    Instead of an eSATA card I would just use a SATA=>eSATA bracket, I expect there are native SATA ports available on the mobo.
  5. ashman
    ashman Gawd
    805
    Mar 28, 2011
  6. Putz
    5,281
    Jul 8, 2002
    the esata bracket might be a good idea, ill check the mobo, i know it has scsi but usually they have a few sata ports
  7. brutalizer
    brutalizer [H]ard|Gawd
    1,593
    Oct 23, 2010
    I am looking for a case with >2 disks, each having individual eSATA cables. With a port multiplier you can use one single eSATA cable to drive all disks, but it gets messy with Solaris and ZFS. So I prefer individual eSATA cables.
    I can buy several single disk cases, but it is easier to have several disks in one single case. Does anyone know of such a case?
  8. thatoneuser
    thatoneuser n00b
    31
    Aug 23, 2013
    Look up Mediasonic ones. Good reviews on newegg. I have a 4bay USB 2.0 version that's worked well.
  9. brutalizer
    1,593
    Oct 23, 2010
    I looked, and found
    http://www.mediasonic.ca/product.php?id=1357292354
    And it seems it uses a port multiplier? It is not four separate eSATA cables?
    I need separate eSATA cables. Anyone knows?
  10. Old Hippie
    Old Hippie [H]ardness Supreme
    6,013
    Oct 31, 2005
    Strange, I don't see anything about a port multiplier.:confused:
  11. Putz
    5,281
    Jul 8, 2002
