I have to test a few things in terms of performance over an internet link and rather than use an off network machine it would be nice if there was a way to throttle the LAN connection to various speeds. I did some quick googling and really was only hitting results for router QoS and ISPs that were throtting (probably not searching for the right terms) so i figured i would stop over here and see if anyone has any suggestions. Does anyone know of an application that will allow you to set the speed of a network connection, preferably between 1.5 and 10mbps.
Thanks
Thanks
