VESA mounting plate (75mmx75mm / 100mmx100mm) info is almost always found on the spec sheets on the manufactures website. you can be fairly sure if VESA isn't mentioned, then the monitor doesn't have it.
i can't tell you specific make/model tho i did recently research for 19/20 inch widescreen monitors (wasn't after LED).
