Cerulean
- Jul 27, 2006
I'm fed up! Recommend me a router that is guaranteed not to die on me for at least 10 years.
Agreed. This is what I will do next time when I have money. My budget is constrained to my mom's checkbook because it's the family router that's gone bad.cheaper alternative is to build a little server and run pfsense or the like on it. best option IMO
Had my Dlink 4300 for more than 5 years.......
It's one of those D-Link EBR-2310's. Weeks (or months) ago it was showing signs of the control panel http://192.168.2.1/ not working by giving a "Page not found" error page and not being loadable in IE6. Now the control panel doesn't even work, but the rest of the router does.
I've seen a 2.1 soho router oobe before. I can't remember what brand it was though.Just out of curiosity, is that the routers address and if it is, did you change it to 192.168.2.1? Normally they are 1.1 or 0.1
Is it possible that you are inputting the wrong IP address to the control panel?
Surprised no on mentioned a DD-WRT router.
I've had my wrt54gl for I think 5 years, maybe more now. Currently run tomato on it with no isseus at all (I do run torrents often with it). Torrents should not kill routers themselves. If you get torrents that kill routers then those routers were crap to begin with. I'm with the guy above that said to put heatsinks on the chips inside the router that get warm. I have a feeling that would help extend the life of the router.I have seen torrents kill a few routers, so if you want a normal router to last, stay away from bittorrent, all the connections can cause problems. If you can't stay away, then get either IPCOP or PFSense. And build the computers that they are going on with good parts. I had a IPCOP box that lasted for 3 years with no issues, i just decided to upgrade it is why it went down. I have never killed one of myh IPCOP/PFSEnse boxes, but I have killed about 3 or 4 normal routers.
Well, fact is most of the home-grade routers (like the WRT54G, etc) just aren't that beefy. Even if you enable QOS, the router just doesn't have enough beef in it to handle that much stuff.
Hence my suggestion if the OP is actually wanting to buy something, the WNDR-3700 is a great high-performance enthusiast router.
