I'm currently looking for a very high CFM 60mm fan to replace the regular stock fan that sits on top of the heatsink in an arcade cabinet that runs on a mATX board/case. Currently it has been having overheating issues which I think could be solved by simply replacing the fan. Noise isn't an issue at all, just looking for whatever pushes the most air. Anyone have any suggestions? I couldn't find antyhing over 25-27CFM on Newegg, so I'm hoping to purchase it elsewhere.
Thanks in advance.
edit; The mobo is an ECS c51gm-m also, if that helps. I believe it's AM2, but I'm unsure of exactly what CPU it is using. I would also be open to a new heatsink/fan combo suggestion, as long as it's cheap (under $10-15).
Thanks in advance.
