Looking for a good replacement to a runco projector
Discussion in 'Home Theater PCs & Equipment' started by DGMurdockIII, Apr 26, 2018.
  1. DGMurdockIII
    DGMurdockIII Limp Gawd
    268
    Jan 16, 2015
    I have a runco projector I'm looking to get an upgrade what projector would you suggest the one I have is from 2002
  2. GoldenTiger
    GoldenTiger 3.5GB GTX 970 Slayer
    17,769
    Dec 2, 2004
    You need to give a lot more info here. Screen size, environment, resolution desired, budget, etc., before anyone can help you.
  3. Nenu
    Nenu Pick your own.....you deserve it.
    17,908
    Apr 28, 2007
    And what you expect from it.
  4. Verge
    Verge [H]ardness Supreme
    5,757
    May 27, 2001
  5. DGMurdockIII
    268
    Jan 16, 2015
    i have a almost 8 foot screen
  6. DGMurdockIII
    268
    Jan 16, 2015
    budget is not a problem just want something that is good and has true 1080p and possibly 4k under 3k and under
  7. Blue Fox
    Blue Fox [H]ardForum Junkie
    11,615
    Jun 9, 2004
    Native 4k isn't happening in your budget unfortunately. Pretty much only Sony manufactures them at this point (except for a single $35k JVC) and the cheapest one is the VPL-VW285ES, which runs $5k. Everything else that advertises 4k is somewhere in-between 1080p and 4k and uses pixel shifting.
    For up to $3k, you can get a high end 1080p projector from Sony or JVC or a not-quite 4k one from say Optoma. I personally prefer LCoS projectors myself and you can look up a decent number of reviews online. Pretty much comes down to what you want feature wise. I don't think you'll need to worry about brightness too much as even with less than optimal light control in your room, your screen is pretty small. At least since you have a Runco currently, you shouldn't have any issues mounting something that's over 25lbs.
    I personally have a Sony VPL-VW90ES, but here are some examples of what you can get given your budget:
    Epson 5040UB
    Sony VPL-HW45ES
    JVC DLA-RS400
  8. Verge
    5,757
    May 27, 2001
    oh yes it is a problem
  9. DGMurdockIII
    268
    Jan 16, 2015
    well can i get some recommendations on a good bluray player and is wireless hdmi worth it
  10. Blue Fox
    11,615
    Jun 9, 2004
    I would probably go with an Xbox One S.
    As for wireless HDMI, the answer is that it depends on the hardware. Only 60GHz units can do uncompressed transmission. Do not bother with 5GHz units. I personally used a Gefen 60GHz one and was quite pleased with the results (selling it now though). No lag or issues with interference. Do keep in mind that there are a few limitations. 60GHz is line of sight and range is only about 10m. You also will be limited to 1080p. There are no 4k units available.
  11. Logan M
    Logan M n00bie
    30
    Nov 25, 2016
    For that budget I'd suggest a Optoma UHD60. $1800 and 4k. It will blow your current projector out of the water. They aren't even comparable in terms of picture quality except maybe black level if your old one is CRT based.
  12. Blue Fox
    11,615
    Jun 9, 2004
    That one is not really 4K. It uses pixel shifting and has a native resolution of 2716x1528.
  13. Logan M
    Logan M n00bie
    30
    Nov 25, 2016
    That's true but it looks amazing either way and is an absolute bargain compared to the true 4k projectors.
  14. Verge
    5,757
    May 27, 2001
    The CR on it is like 700:1. It looks about as good as his old runco from 2002.
    Ocellaris likes this.
