Looking for a good atmoic wall clock
Discussion in 'Computers & Gadgets' started by DGMurdockIII, Jan 30, 2018.
  1. DGMurdockIII
    DGMurdockIII Limp Gawd
    268
    Jan 16, 2015
    I'm lookin for a goog atmoic wall clock any suggsuggest
  2. Brian_B
    Brian_B [H]ard|Gawd
    1,469
    Mar 23, 2012
  3. RazorWind
    RazorWind 2[H]4U
    3,011
    Feb 11, 2001
    I don't think you can just buy a real atomic clock. There are commercially available ones, but they're more of a science-grade thing that you'd need to convince the sales guy at the manufacturer to sell to you directly.
    There are clocks that can synchronize to the official ones using NTP or GPS, but they just look like regular clocks.
    kirbyrj likes this.
  4. margrave
    margrave [H]Lite
    92
    Feb 15, 2018
    I have lots of atomic clocks.
    Most of them are plastic.
    But plastic is made of atoms.
    So they're atomic clocks. :)
  5. ajrettke33
    ajrettke33 [H]Lite
    109
    Dec 7, 2014
    I'd just get any internet clock....you probably can't afford a real atomic one
  6. DGMurdockIII
    268
    Jan 16, 2015
    The la cross one looks good and what counts as a real atomic clock
  7. Zepher
    Zepher [H]ipster Replacement
    16,257
    Sep 29, 2001
    I have a few of the lacross ones, a vertical one and horizontal one.
  8. pendragon1
    pendragon1 [H]ardForum Junkie
    10,706
    Oct 7, 2000
    that site has a bunch, I just link to the analog section.
  9. pendragon1
    10,706
    Oct 7, 2000
  10. Zepher
    16,257
    Sep 29, 2001
    I like them. Mainly got them for the temp gauges though
    pendragon1 likes this.
  11. defaultluser
    defaultluser I B Dum
    11,752
    Jan 14, 2006
    Just be aware, the WWVB radio sync clocks don't work so well if you don't mount them ON a window. It's a pretty weak signal if you're not near Colorado, so it might not work anywhere in your house if you live on the East Coast.
    I live in MD, and had to take the fancy case off the LaCross I bought and put it in a window on the west side of the house just to get it to sync...and then it never synced again.
    Wifi clocks (they use NTP to sync, just like any other internet device) are the only guaranteed way to get updates, and those are much more expensive. I decided I'll just do it by-hand.
    LaCrosse clocks "work," but that definition of "work" may require some serous effort on your part. You probably can't mount it in a hallway, like most normal clocks are.
  12. Nenu
    Nenu PM Kyle for the TItle You Pick.
    17,955
    Apr 28, 2007
    Wha accuraccuraness u look fur?
  13. defaultluser
    11,752
    Jan 14, 2006
    For clarifi
    A real Atomic Clock is not easy to get hold of. All wall clocks labeled "Atomic" get their time from a radio station in Ft. Collins, Colorado. That's synced to the US Atomic clock.
    https://en.wikipedia.org/wiki/WWVB
    Network Time Protocol, or NTP, is how internet-connected clocks get the EXACT SAME TIME. So Wifi clocks are exactly the same accuracy as "Atomic" radio clocks.
    Atomic radio clocks were created in the 1980s, before the Internet became popular, which is why they are so cheap today. It will take some time before Wifi clocks are as cheap.
    The success of Alexa and home automation has finally opened the door for Wifi convenience devices in the home, so this company is adding an alarm cock to the mix. Price just needs to drop by $20, and we'll have a winner!
    https://www.amazon.com/Vobot-Speake...TF8&qid=1521125549&sr=1-8&keywords=wifi+clock
