What 120 mm fan is there out there that is both super-quiet and has a four-pin hinge? That is, a four-pin connector where the interlocking post is the full-width of the four pins. I've attached a picture.
looks like an oem part, like the ones from Compaq/hp. youll need to search the part number to get an exact replacement or get any pwm fan and transplant the connector.
It may be possible to modify a standard fan connector by cutting off one of those sides, but you would then need to make sure it uses the same pinout. The oem might have used a different pinout just to mess with people. Without a part number and some info abouy the system it's hard to say anything more.
