Looking for a couple of Firefox extensions
Discussion in 'General Software' started by Morlock, Feb 12, 2018 at 5:04 PM.
  1. Morlock
    Morlock Limp Gawd
    350
    Jun 8, 2012
    I'm looking for a Firefox add-on to give me control of whether images are downloaded/displayed, or not (I need this for a couple of different rigs, and in one case "hidden" is as good as "not downloaded," and in the other case, it is not).
    Specifically, wanted features include:
    Turn images on/off globally in the browser
    Turn images on/off in the current tab
    Create exceptions for specific URL strings, like Firefox had before "progress" killed it. E.g., I had an exception for google image search's "gstatic" URL, so thumbnail images in google image search results always displayed.
    I'm also looking for something similar for stuff like flash, java, and javascript. I know the Developer Kit will let me turn styles on and off, and possibly flash/java/javascript, but I'm looking for something simpler and quicker, that works more like QuickJava did for Firefox, before "progress" killed it.
    I'm not optimistic, but I figure it can't hurt to ask.
  2. 0_0
    0_0 n00bie
    17
    Dec 24, 2017
    I think noscript might be configurable to do all that. Might require a bit of reading to do though.
  3. cjcox
    cjcox Gawd
    577
    Jun 7, 2004
    Easy Image Blocker?
    This is going to be harder. Proxies used to do this sort of stuff, but now that everything is SSL'd, you can't see beyond the domain (can't see the rest of the url or parms).
  4. Morlock
    Morlock Limp Gawd
    350
    Jun 8, 2012
    I thought I posted that I found an extension that does it (SettingSanity), but I guess it didn't go through. In any event, it wouldn't help because it doesn't work on Quantum. I already have extensions working on FF 56 that do all of this - was just looking for a way to do it all on current versions.
    Noob, does noscript generally allow you to put the command in a toolbar button?
    CJ, will look at EIB, thanks.
  5. 0_0
    0_0 n00bie
    17
    Dec 24, 2017
    First time I've been called Noob in a while haha :D I'm not sure though tbh. I use noscript but have never really got too crazy with it. I think it's likely you'll need to do a bit of reading on what it can do and how to do it. But I understand if you don't want to bother with that.
  6. Morlock
    Morlock Limp Gawd
    350
    Jun 8, 2012
    Haha my bad I misread your label for your handle. Yeah noscript was a bit like space shuttle controls last time I looked; that's why I asked.
  7. 0_0
    0_0 n00bie
    17
    Dec 24, 2017
    Haha no probs :)
