Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
$60.98 - StarTech 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card
7 ports...
Do note that you can connect multiple devices to a single USB port, you just need to get a USB HUB. Much cheaper than getting an actual USB controller card.
Another question, are you looking for a PCIe card because you don't have any PCI slots, or because you think the PCIe card will be faster (it won't)? In any case, if you are just looking for a cheapo card then something like this http://www.amazon.com/Syba-SD-PEX-VT4E4I-Chipset-1394a-Combo/dp/B000ZD0CPU for $38 might be what you are looking for. 3USB2, 3 1394a.
