looing for a uTorrent alternative
silk186
I've used uTorrent for years but now I'm looking for something new.
I'm tired of the advertisements and I can't get the labeling system to work.
I'm checking out Deluge right now. The UI isn't as nice but no adds.
Anything else I should try? I'm setting it up to work with sickrage.
silk186
Nice, I will give them a try
Wow, that was way too easy... should have done that long ago.
Go setting>>advanced and in filter search for 3 values and change them to false. upsell, sponsored and offer
drdeutsch
Another vote for qbittorrent.
Tixati is nice, but is flagged on some private sites, so you may have trouble. qbittorrent has all the features, looks good, labeling works, and is lightweight. WIN.
HeavensCloud
Oswego, not shitty as Buffalo
Switched to qB as well. The ads and pop ups of uT got on my nerves, sell-outs.
redrage
I'm using deluge right now don't have a link but quick google should turn it up.
I just liked the plugin system and it has a plugin for blocking specified ip's that i liked.. and is fairly light weight and out of the way. also no ads.
KoolDrew
uTorrent 2.2.1, Deluge or qBittorent are all solid options.
I recently made the switch from uTorrent to qB and have been quite happy with it.
