I am using a Belkin KVM for years. I recently decided to route audio to my speaker though it. However, this introduced noise/hum. Tried several things, including getting a ground loop idolator for the audio going from KVM to speaker. However, this didn't fix anything.
After testing various combinations I noticed that the humm is gone when disconnecting the keyboard from the KVM. I am using a Logitech K740.
It is caused by the backlit function. If I keep the light at 100% or off no noise. The keyboard dimmer is causing this..
Is there a way to cure this other than to replace they keyboard?
