I bought G733, few days ago, and I can see, that the default audio format maxed is 16 bit, 48000 Hz (CD Quality).
I use VoiceMeeter, to modify the audio output, that can increase the bitrate and format, up to 192000 Hz 24 bit, as you know.
However, I want to be sure, that doing so has no risk, to wear off, or damage the headset. Can someone be assertive, that it is, or it is not.
