So, after about a couple of years of use, this keyboard started to have issues with keys not working right. Double clicks or clicks that only occured after mashing the button repeadetly etc. Only happens to the same keys, which is basically the entire top row from F1 to Pause, the entire numpad and the lowest row from ctrl to ctrl (barring the space bar which i was somehow able to fix permantently through sheer violence).
I've tried cleaning the keyboard several times, with last time literally bathing the switches in rubbing alcohol. This fixed the problem, but only for a short while, until it started again. I futively (or so i thought) blew over the affected keys with my mouth without even removing the caps, just venting frustration while i considered dissassembling the whole thing in my head, and low and behold, the keys work after that, but only for a few minutes.
Not sure what is going on here. Can it be that within minutes dust somehow settles inside the effected switches? Why would blowing over the key without even removing the caps work, and why can't i achieve permanent cleaning after literally drowning the switches in liquid, if all it takes to make them work (if even temporarily) is a bit of air? This is driving me nuts every time i need to use the affected keys now i have to blow over them my family is even starting to make fun of me as they hear me doing it inside my own room.
I checked a video on how to take the thing apart and it seems the PCB is right under the top metal plate, so i'm not sure i can even reach the contacts better that way:
View: https://www.youtube.com/watch?v=SqvzSd5FX1c
I'm assuming taking the PCB off the plate would mean ripping the switches apart. I could just let isopropyl alcohol drip down from the side of the PCB. Can't think of anything else i could do.
