Well, you have one now, the new Roccat Kone Pro Air. I just got one early for review. Really nice and the software is tits.I wish I could do the same. The problem is that I can't find a mouse that's any better. Especially the wireless G502.
There are better wireless keyboards than my G613, but many of those have their own proprietary software, too. Doubling down on Logitech has allowed me to at least narrow the suck down to GHUB.
It's your standard button gaming mouse, for sure. it's not an MMO mouse, if you need 15 macros, etc., it's not that. it's solid, though.Unless there's a model that's different from this one: https://www.roccat.com/products/kone-pro-air, I'm going to need more buttons than that. That's just the standard 'ol Intellimouse layout.
The software allows you to assign individual clicks to the mouse wheel up and down movement. So three are two more buttons. The mouse is SUPER light to, almost floating in your hand--I like some weight to my mouse. But, if you like a light mouse. . . .I don't really need a pile of buttons, but that's pretty bare bones. I like having at least 3 shoulder buttons and another index finger button (or two) as well. I can't go back to an Intellimouse design at this point.
hi ya i dont suppose you got a copy of the old g-hub as i actually never had a n issue with it but am having issues with hte new version.. had to del;ete as froze my pc 3 times and reinstal 4 times grrr if you have a copy can you share?The last time I used GHUB it was terrible, about a year ago. I couldn't believe how convoluted it was, and people on other forums were saying they couldn't even figure out how to make simple macros with it.
And, it was bad.
Has anyone used it recently? I see they have an update from December 2020.
And, it was bad.
I don't. I stopped using Logitech shitware after I got my above pictured Roccatt mouse. Their macro software allows you to configure any keyboard keys to the mouse macro. Unlike Logitech, where it only allows you to macro it's own boards and mice, Roccatt did the right thing and allows you to not only set up your Roccat mouse, but an any keyboard binds to the macro, regardless of which keyboard you are using. Super useful. That, and the Roccat mouse removed all of my elbow pain, well, 97% of it. The Logitech G305 was crippling me. Try Roccat, man. You'll never go back to Logitech.hi ya i dont suppose you got a copy of the old g-hub as i actually never had a n issue with it but am having issues with hte new version.. had to del;ete as froze my pc 3 times and reinstal 4 times grrr if you have a copy can you share?
Sadly, I can't. I tried and it wouldn't recognize the G502 Lightspeed.Glad I can still use the old pre hub version
GHub is kind of a pain. However, recently I reintalled windows and it actually let me reload my onboard profile from the mouse back onto the computer which was unexpected.
Works for the mouse, but not the keyboards.That's the "good" thing about it, although that's more about the devices than the software. If you're happy with a specific config for your mouse/keyboard, you can set it up once and never use G Hub again. I think you can even uninstall G Hub after reloading your profiles if you want.
It'll retain light/settings through a reboot. However, at least on mine, if you do a shutdown/power-off they will go away.At least for my G915, it seems to. I just uninstalled G Hub and my light settings and G keys are still retained even after a reboot. With my prior G613 it didn't, though. Luckily there isn't much to program on that one.
Same here. Using it with a G915 and a G703 and no issues on my main PC.I have it running on two of my machines with no issues, G815 and G604 on both.
My main rig also has LGS installed for my G13.
I dumped Logitech for ROCCAT. Their mice are moire comfortable and their software works perfectly and is intuitive. Their CS is stellar too.August 2022. Still sucks, confirmed.
I last tried G-hub in 2020. I have a G502 hero. I've been using the Onboard Memory Manager ever since tossing that old version. g-hub is vastly over-complicated, non-intuitive, klunky, and just basically a pain in the ass. While poking my way around the software - a few small option changes here and there - I clicked on the 'onboard memory manager' button in it. Looked at it. No idea wtf they are trying to make easier for me. So I uninstall G-hub again. Fire up the Onboard Memory Manager...."Settings will not take effect until this device is switched to onboard mode within G HUB". What. The actual. Flibbermuff. I'm going to try a reboot first just in case that will "free" the onboard memory manager, as I seriously don't want to have to go through the tediously long and slow install just to flip a switch then uninstall again.
How can Logitech consider this release-quality software? Oh boy, a big new pulsating orb thingy, but the actual software seems barely unchanged, two years later.
It's a great mouse. Thank [insert diety] the onboard memory manager actually works. Otherwise I'd have tossed thing thing long ago.
I'm lucky I can still get away with the old software.
Im starting to not like Logitech mouses anymore. The old ones used to last me 5+ years easily. Now I am finding myself replacing it every 2-3 years. Some even shorter than that, a lot of the old ones are still kicking around after a decade but a lot of the recent ones have double clicking issues or just stopped working right outside of warranty. I love the ergonmics though and I find myself just buying an extra or 2 whenever they are on sale.They changed the UI again recently. I can't decide if it's worse or better, but it's mainly just a visual change. Luckily, if you use the onboard memory function you never have to actually use it again. It sucks, but I can put up with almost anything if I only have to use it once. I like the hardware.
I too am enjoying my G502 Hero Lightspeed or whatever its called. This is tempting even though it probably wouldn't be any better functionally.Just in time for some new G502 optical mice...
https://ir.logitech.com/press-relea...Wired-Wireless-and-PLUS-Versions/default.aspx
I love my current wireless G502, but damn it was expensive. These are even more so.
Mice and keyboards usually look pretty worn after a year or two with me given how much I use my computer. Since I use it for work and gaming. I tend to replace them at roughly that interval.I figure I'll end up replacing mine with one of these if I ever have any issues with it. I usually need a new mouse every 4-5 years, so this one should have another 2 years of life. Hopefully by then the newer models will come down in price a little.
