Logitech Ergo K860 cant function in bios
markm75
At least when used with the motherboard's bluetooth and not the dongle that came with it (not sure if using the dongle that came with it would avoid this issue), if you reboot the pc the keyboard wont work to enter the bios, you must connect a wired keyboard.
Does anyone know of a workaround?
Thanks in advance
Starfalcon
There isnt one, bluetooth wont be active on the board until windows loads up the driver for it. If the dongle is a USB to bluetooth, that may work.
