List Your Firefox Extensions
Abu Som3a
simple, huh?
Browse Images
ChatZilla
ColorfulTabs
CookieSafe
CustomizeGoogle
DOM Inspector
Download Statusbar
DownThemAll!
Fasterfox
FireFTP
FoxLingo
Greasemonkey
IE Tab
Linky
McAfee SiteAdvisor
Mouse Gestures
StumbleUpon
Tab Mix Plus
VideoDownloader
WOT
Memory Usage with only this 'new thread' tab open: 50MB
GJSNeptune
The amount you have installed and enabled is ridiculous.
We cannot, however, discuss blocking [H] ads.
TheRules said:
(23) Any discussion of AD BLOCKING software or instruction for using ad blocking regarding this forum or any other discussion in general of attempting to block advertisement will result in a no questions asked permanent ban on your account. This is not done lightly, rather deliberately to deny access to those who choose to utilize this forum, but not support our sponsors. It takes money to finance the cost of bandwidth, especially a forum of this size and if you don't care enough to support us through our advertisers, then we don't need your business. This will be the only warning with no discussion.
Monkey34
"graphic product sales generator shield for my browser"-Plus;) (only for surfing - Disabled for all the [H])
((I didn't say it!))
Greasemonkey
Fasterfox
Mcafee Siteadvisor
Thats enough for me.
Mincho
I find i am unable to live without Mousegestures and its rocker gesture to go back (hold r click and then left click)
Also,
BugmeNot
Download Statusbar (better than an external window imo)
Foxmarks (awesome)
Tabbrowser Preferences
Hypernova
Allow me to quote myself:
The configuration has changed a bit since then but it's mostly the same. I have since migrated to FF2 and the count has increased to 87 extensions.
There is a prophecy that says if a man can install and make use of 100 extensions he will reach a state of zen.
Still running FF 1.5, and it the portable version.
There only 10 that I don't really use, the whole interface is also rather heavily modded which is why I'm yet to shift to FF 2 since it will take hrs trying to move every thing and retweak.
1. AIRoboformToolbarforFirefox{6.8.3}
2. ActiveStopButton{1.2}
3. A******Filterset.GUpdater{0.3.0.4}
4. A*****Plus{0.7.2.4}
5. All-in-OneSidebar{0.7.1}
6. BatchDownload{1.1.4}
7. CacheStatus{0.7.1}
8. CharacterIdentifier{0.1.1}
9. ChatZilla{0.9.77}
10. CompactLibraryExtensionOrganizerCLEO{2.0}
11. CookieSafe{2.0.6}
12. CustomizeGoogle{0.55}
13. CuteMenus-CrystalSVG{1.8.2.1}
14. DictionarySearch{2.0}
15. DownThemAll{0.9.9.7}
16. DownloadStatusbar{0.9.4.5}
17. DragToScroll{0.4}
18. ExifViewer{1.10}
19. ExtendedLinkProperties{1.2.3}
20. ExtendedStatusbar{1.2.5}
21. Feedview{0.9.8}
22. FireCal{1.2.3}
23. FireEncrypter{3.0}
24. FireFTP{0.94.6}
25. FirefoxExtensionBackupExtensionFEBE{4.0.4}
26. FirefoxShowcase{0.9.0.1}
27. Fission{0.8.7}
28. FlashGot{0.5.97.03}
29. Flashblock{1.5.2}
30. Forecastfox{0.9.3.1}
31. FoxyProxy{2.3}
32. GmailSpace{0.5.3}
33. GooglePreview{2.1.2}
34. GoogleToolbarforFirefox{2.1.20060807W}
35. IETab{1.3.0.20070110}
36. Image-Show-Hide{0.2}
37. ImageBot{3.1.5}
38. ImageZoom{0.2.7}
39. JSView{1.2.5}
40. LinkAlert{0.6.2}
41. LinkEvaluator{0.9.9.3}
42. Locationbar{0.3.6}
43. MRTechLinkWrapper{2.1}
44. MRTechLocalInstall{5.3.2.3}
45. MediaPlayerConnectivity{0.8.3}
46. MenuEditor{1.2.3}
47. MinimizeToTray{0.0.1.2006102615+}
48. NewTongWenTang{0.2.9.8.5}
49. OrganizeStatusBar{0.5}
50. PageStyle2Tab{0.7.3}
51. PageUpdateChecker{0.3.1}
52. Pterodactl{0.4.2}
53. RSSTicker{1.8.10}
54. ResurrectPages{1.0.5}
55. SaveImageinFolder{1.1.1}
56. SaveLinkinFolder{1.3.1}
57. SearchPluginHacks{0.1.3}
58. ShowIP{0.8.05}
59. ShowImage{0.4.1}
60. SmoothWheel{0.44.7.20050605}
61. Splash{1.2.2}
62. TabEffect{1.1}
63. TabMixPlus{0.3.5.2}
64. TextLink{1.3.2006100702}
65. Translate{0.6.0.8}
66. TweakNetwork{1.1.1}
67. UnPlug{1.5.4}
68. UpdateNotifier{0.1.5.2}
69. ViewCookiesCS{1.0.7}
70. ViewSourceChart{2.5.02}
71. WikiPediaLookupExtension{0.2}
72. externalIP{0.9.7}
73. gTranslate{0.3.1}
74. repagination{2006.4.5}
75. translator{1.0.4.3}
If I had that many extensions I would forget what I had and do it the long way half the time so I just use adblock plus, download statusbar, forecast fox, and tiny menu.
D
Deleted member 133315
Guest
better still, get a mouse with side butons that whe you push one of the side thumb buttons the browser will go forward and back ;)
D
Guest
your long list of extensions, all i can really say to that is,
That my friend is stupidity.
Hypernova
They enhance the function of FF which I do use from time to time. The RAM cost isn't big anyway. 100MB at open is perfectly OK for me since I have plenty of ram. And it seems to work better on vista too. After whole day of use the usage hovers around 130MB, you just have to know how to tweak it.
l3ender
This is what I have:
-Broadband Speed Test and Diagnostics
-Chatzilla
-Download Statusbar
-Full Screen Homestar Runner :)
-gTranslate
-IE Tab
-MR Tech Local Install
-Tab Mix Plus
-Update Notifier
-Web Search Pro
I use them all. I consider Web Search Pro the one I need the most.
Sucka
GJSNeptune
-img snip-
Eh hem.
GJSNeptune
Sucka, thanks for introducing me to Stylish. I love your Google, and I'm using the blue version (have both saved though). One of the best add-ons I've come across yet.
Sucka
Thanks. Google being my home page, it's been awsome to have it look a little different. I also use the gray theme for youtube and google video, just adds a little flavor to some otherwise boring sites.
GJSNeptune
Aye, I just came across the YouTube one. Will the Google userstyle change its logo when Google does?
GJSNeptune
Nope, it will remain constant. It won't change with the seasons and holidays and all that :(
I figured, since the style gives the logo a reflection. Maybe the author will figure out how to make it sync, and update the style. Pipe dream? Probably.
leSLIe
Fisting is Too Mainstream for Me
here is mine
PasteIP 1.7 by Michael Newton
Cooliris Previews 2.1 by The Cooliris Team
DownThemAll! 0.9.9.7 by Federico Parodi and Stefano Verna
Leet Key 1.3.2 by Roman Mironenko
TorrentBar 0.9.1.5 by LukasS
Tab Mix Plus 0.3.5.2 by CPU, onemen
Deutsches Wörterbuch 1.0.1 by Robert Kaiser (KaiRo)
Pennypacker 1.2.1 by Anson Parker
Fasterfox 2.0.0 by Tony Gentilcore
Download Statusbar 0.9.4.5.1 by Devon Jensen
FlashGot 0.5.97.03 by Giorgio Maone
PDF Download 0.7.8 by Denis Remondini
Wikiseek Search Extension for Wikipedia
DragNDrop Toolbars 0.0.0.4 by Reivax
ErrorZilla Mod 0.2 by Jay Baldwin
Live IP Address 1.6 by Anastasios Monacho
Mouse Gestures 1.5.2 by Optimoz Team
Morse 0.6 by Jan Kechel
easyGestures 4.0.2 by Ons Besbes
Tab Effect 1.1 by s
MSN URL 0.22 by s
Torrent Finder Toolbar 1.1 by Walid A. GadElKarim
SmoothWheel 0.44.7
Addictive Typing Lessons 1.1.1 by Tom Kennedy
Beer oclock 1.2b by mrspeaker
File Encrypter 3.0 by Ronald van den Heetkamp
Password Composer 0.9 by Johannes la Poutre
Confuscator! 0.5.1 by Borkur Steingrimsson
YaCyBar 0.1.3 by Alexander Schier
