I just built a linux server box running Clarkconnect linux (red hat 9.0 striped down). I am mainly using it as a loca file/print server right now. Running Webmin 1.130.
My issues are coming from trying to use Webmin to control the server. The problem I am having is installing server modules. I have tried to install; fetchmail, apache, mysql, and other server modules. **the issues is not just with server modules but mainly server modules**
I will install the modules through the standard module install tab built into Webmin. After installing it says that the modules are installed into -- /usr/libexec/webmin/module name --. After the install I will go into the server tab and I will have the error -- The module program module could not be found. Maybe module is not installed on your system, or your module configuration is incorrect.
I am not sure how to get my modules to install properly or configured properly. Please someone help me uderstand what I am doing wrong or give a link to a How-to on webmin
thank you,
michael
thank you,
michael
