Linux Mint 15 with KDE
Discussion in 'Operating Systems' started by Blacklash, Aug 7, 2013.
  1. Blacklash
    Blacklash [H]ard|Gawd
    1,893
    Jun 16, 2004
    If you're on something like Win 7 and you've been toying with the idea of trying Linux, give Mint 15 with KDE a whirl. I adapted to it fairly quickly.
    I've been experimenting with it off of a bootable usb drive. I used the Universal-USB-Installer-1.9.3.9 to create it.
    It's solid for general use and multimedia. I've not had issues yet. Processor and GPU = FX 6300 @ 4.66GHz and GTX 660.
  2. DPI
    DPI Nitpick Police
    10,955
    Apr 20, 2013
    Good info, thanks! I've heard good things about MINT
    Have you tried Ubuntu at all? If so how do the two compare?
  3. Citizen86
    Citizen86 [H]ardness Supreme
    4,572
    Feb 20, 2007
    Linux Mint is based off of Ubuntu, which is based off of Debian. They're both good for newcomers to Linux, although lately Linux Mint has been getting better reviews than Ubuntu.
    When you go to check out Linux Mint, keep in mind that the different versions, Mate, Cinnamon, KDE, etc. are all just the different desktop environments you can choose from. Basically, different desktop systems that are different in their own ways.
    KDE is very full-featured. I'm personally using Cinnamon, I find it's easy to use but doesn't get int the way. Here's what my current desktop looks like: Link
    Dual desktop, Cairo Dock is what is used as the bottom dock. It's a little OS X like, but not too much. I like it for opening programs and folders.
    Not to derail the KDE comment, but choice of DE is very much up to personal preference. Gotta try them all!
  4. Blacklash
    1,893
    Jun 16, 2004
    I didn't try Ubuntu long enough to make a fair assessment of it.
    MInt 15 with KDE is ready to handle most all multimedia as soon as it boots.
    I'd agree with Citizen86, folks should try different versions and DE for themselves.
    I had an easy time flowing from Win 7 to Mint 15 with KDE, that's why I suggested it.
    It's slick and felt similar.
    Eventually, I will try Mint 15 with Cinnamon, MATE and then Xfce simply to compare.
  5. Citizen86
    4,572
    Feb 20, 2007
    Good to hear Blacklash, not everyone has the same easy transition from Windows.
    Also, if you're new to Linux, don't be afraid of the command line. It's your friend, not your enemy :D
  6. Blacklash
    1,893
    Jun 16, 2004
    Citizen86,
    Feedback from experienced Linux users is more than welcome in this thread; it's not a "derail" at all.
    Yes, I'm tackling the command line business now; I'm working on getting Steam and Skyrim up and running.
    So far I've got the nVidia 319.32 driver working correctly, go me :p
  7. Citizen86
    4,572
    Feb 20, 2007
    For any Steam games that aren't Linux based, I'd suggest using PlayOnLinux.
    Also, make sure you get the updated version, you can follow these instructions: http://www.ubuntuupdates.org/ppa/playonlinux
    I don't use everything PlayOnLinux has to offer, but I do use it for separated installations of Wine when I need them. Sometimes programs/games need specific installations of whatever, so having them in their own Wine installation helps tremendously.
  8. Blacklash
    1,893
    Jun 16, 2004
    Ah very good. Thanks for the link.
    I'm looking into Wine now. As I said, my goal is to get my Steam version of Skyrim up and going on Mint 15 with KDE.
    It's mostly what I play.
  9. Citizen86
    4,572
    Feb 20, 2007
    It's the only way you'll be able to play Skyrim ;)
    http://www.winehq.org
