So, my grandma's computer may have bit the dust. She's remote, and I haven't seen the machine yet so it may be a simple fix. However, if it is dead, it'll be time to look at a new one.
Since it's a disruption, I figured I'd explore some options with the rest of the family before just getting her another Win10 box off the shelf at bestbuy/walmart and having to deal with all the preconfigured/value added "stuff" that comes along with it. Her use case is really so simple that an iPad would be a good contender, and I'm also going to check out a Chromebox.
Use Case:
* E-mail
* Web browsing
* Photo printing (I don't have the exact model at this moment, but it's an HP deskjet of some sort. Up to 5 years old)
* She's also pretty healthy overall, so I don't think I need to consider accessibility helpers.
I know some of you have converted non-techie parents and grandparents successfully. So, I'm curious - What did that look like and how has it gone?
In display environment - I'm wondering if I should make a special effort to replicate the Windows XP/7 layout, or if we should just start with a fresh concept/set of instructions and see how it goes. She's still very sharp, but has always been very procedural. I have my own ideas, but would love to hear if you had any DE + extension experience that you found worked or didn't work for grandparent types?
Use Case:
* Web browsing
