Linksys WRT54G Problems, Help please!
Discussion in 'Networking & Security' started by dotZIP, Aug 26, 2004.
  1. dotZIP
    dotZIP Limp Gawd
    453
    Mar 29, 2003
    I just moved to a person's basement. He has DSL connected with PPPOE. I set up my router on his connection so I can get the Internet on my computer downstairs.
    It seems to work except for the fact that some sites work while others won't. MSN Messenger refuses to connect, microsoft sites in general are slow, there are some other sites that I can't seem to connect to either, like my bank's online banking or my university's email service.
    Any help would be greatly appreciated, thank you in advance
  2. versello
    versello 2[H]4U
    2,062
    Nov 19, 2003
    If you weren't connected behind a router, do those sites you mentioned work fine?
  3. dotZIP
    dotZIP Limp Gawd
    453
    Mar 29, 2003
    Yeah, they do when I'm not behind the router
  4. IceWindus
    IceWindus n00b
    12
    Mar 8, 2004
    Perhaps some more incite into his setup would help. Does he have a modem thats plugged into another router doing PPPoE or is it just the modem? Does he have a switch plugged in to give NATed DHCP'ed IP addresses? Are you doing the PPPoE authentication with your router or as he set yours up as a bridge?
  5. dotZIP
    dotZIP Limp Gawd
    453
    Mar 29, 2003
    His DSL modem is plugged into my router, which goes into his computer and goes to mine via wireless. PPPoE is done with my router. There are no switches, just a DSL modem, a router, his computer and my computer.
  6. IceWindus
    IceWindus n00b
    12
    Mar 8, 2004
    Can you just use just the modem to connect to the internet? That way you can see if the router is causing your problems.
  7. dotZIP
    dotZIP Limp Gawd
    453
    Mar 29, 2003
    It is the router causing the problems. With just the modem, those sites work fine.
  8. bigstusexy
    bigstusexy 2[H]4U
    3,146
    Jan 28, 2002
    is the router hading you its address as the dns server or the two supplied by the isP?
  9. dotZIP
    dotZIP Limp Gawd
    453
    Mar 29, 2003
    I just called Linksys today, turns out, I had to change the MTU from auto to 1440, I guess the ISP was being weird
  10. omega-x
    omega-x 2[H]4U
    3,073
    Jun 21, 2003
    not weird. MS stuff breaks with the MTU at 1500 for some reason.
    known issue!
  11. versello
    versello 2[H]4U
    2,062
    Nov 19, 2003
    Ah, heh. I had a similar prob like that when I was using Verizon.
  12. dotZIP
    dotZIP Limp Gawd
    453
    Mar 29, 2003
    The auto sets the MTU at 1492 :p
