Since there have been many posts recently "What wireless solution should I choose?, cry cry cry" and I keep answering with the same answer, here is a post that should answer some questions.
Why should I purchase a Linksys WRT54G Wireless Router?
- This router runs the 802.11g standard (54MPbs)
- This router has good performance and documentation right out of the box.
- The range is not phenominal but it ranks very high amongst others in my book.
I keep hearing about this "3rd Party Firmware" for the WRT54G/WRT54GS, what is it?
- There are a few options you have with the WRT,
WiFi-Box, Sveasoft's Firmware, and HyperWRT
With Sveasoft there are a few different versions to choose from. Read the documentation carefully and choose which one you would like to go with. I personally recommend the later versions of Alchemy.
Options I have seen in the Alchemy revision firmwares
- Wireless Bridging (The bridged WRT can connect clients via wireless AND via CAT5)
- XMIT adjustment options (Bumping up juice to antennas for extended range)
- The whole WDS feature just blows me away, read documentation because that is a whole 'nother scenario to dig into.
I'll add to this when I can think of something I may of forgotten.
