Limited width/depth available; Need to house i9-9900k + 2080 ti
QQuxa
Hey guys,
so I'm in a stupid situation where my case has to fit into 250mm width (thats maximum there is, so I need to leave some space around it for airflow) and 500mm depth (need to leave some room for cables back there). So ideally <210mm wide case.
I also want to fit i9-9900k + 2080 ti into the case.
I am looking at Define C / Meshify C. Any better options out there?
Thanks.
You plan to overclock much? There are some small form factor cases that would fit the bill, but you usually trade cooling for space unless you wanna do a crazy compact watercooled build.
Meshify is a good option, so is the Phanteks P350X (200mm), NZXT S340 (203mm) or H500 (210mm). I'd definitely go with the H500 over the S340, personally.
A question about your depth: Will the hot air have any room to escape back there, or are you creating a hotbox and stuffing it with cables? It might not be a good idea, and you might want to think about alternate airflow solutions, like bottom to top.
I'd probably do the back and top as intake, the front as exhaust. I'd be worried the rear alone wouldn't have enough fresh (cool) air available.
