D
I've got an older article of theirs saved off that used an ACER Revo 1600 to do an XBMC setup.
Pity I found it well after the 1600 had been discontinued and now shows up on EBay for 2x-3x the original price most times for a used one.
It would work so well for my mother for her DVD TV shows since her mobility is getting very limited in her old age.
Great article. IMHO, they can't really call it a "play anything" media center unless it has a TV tuner to play live TV. Kick ass, yes. Play everything, no.
The day I can stream every single TV show I watch legally (getting closer everyday) or XBMC supports cablecard is the day I switch over. I will definitely be referencing this article.
Thats a great idea. Never heard of it. Thank you.Why not use something like ForTheRecord as a client -> server setup. Have a quad hd runner setup on a standalone server at home with live and recorded tv streams sent out to the media centres on my home network. Xmbc has stables builds available that have all the tv tuner client software built in available, although I personally use media portal.
XBMC isn't [H] until it handles Live TV better.
Other then that, XBMC is a good choice for the less technical folks in terms of setting up codecs. However, the input usability and navigation leaves a bit to be desired as each skin can be completely different.
I have a few issues with the setup - I blame win7. Pretty frequently the video is choppy until I reboot...once in a while after reboot my ATI HD43xx card loses the overscan setting (and I have to reset it). Couldn't get DVXA video acceleration working for a while (fixed by AMD driver update). Typical windows stuff. More RAM might help if I ever get some money (too poor right now)..
Interesting... I've been having the same issue with choppy video on my setup. A reboot fixes it every time. I had assumed it was because I have virtualized my HTPC on an ESXi box using vmdirectpath for the video out...
Why not use something like ForTheRecord as a client -> server setup. Have a quad hd tuner setup on a standalone server at home with live and recorded tv streams sent out to the media centres on my home network. Xmbc has stables builds available that have all the tv tuner client software built in available, although I personally use media portal.
Interesting stuff, I guess I've been in a hole becuase I never knew what a NAS was before I read that article!
I ran out into the garage and I have a Circa 2001 Compaq computer. It's a Pentium 4, IDE, only has 1 drive bay 512 megs of RAM and two PCI slots sitting out there someone asked me to recycle.
I'm thinking I could use freenas with this but since the HD has less capacy than the flash memory in my phone I'd need to replace it. So I'm guessing I just get a PCI SATA card and then find a PCI gigabit eithernet card and put in a decent sized hard drive?
I so badly want to get on board with using pc based tuning for live/recorded tv, but the sticking point for me is finding a solution that can consistently and accurately do commflagging/removal. If I can't have a solution that can handle that, its not worth the added hassle over a simple dvr, and to date any solution I've seen is below 90% success.
XBMC is still trashy. Crashes when searching media files , 24p doesn't work correctly stutters like crazy (does not do this when using individual players like MPC , VLAN and so on). It seems it still has some growing to do.
Sounds like a personal issue to me.
I tried for 3 hours to figure out the stuttering issue (lots of people have this problem) and I simply can't stop it unless I switch to 60p from 24p. This (at least what I think) ruins my blu ray rips because they are meant to watch at 24p.
